Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Magnetic field around copper plate coil › Reply To: Magnetic field around copper plate coil
Norbert Gal
Slowly, I figure out the problem, I dont have a connections in the model, this is an imported .STP file. But looks like I am not able to add connections between faces because because that button is grayed out. Does anyone knows why? Thanks.
