Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Inertial Relief › Reply To: Inertial Relief
September 14, 2023 at 10:17 am
Hi Marcos,
This option applies only to the linear static structural analyses. However, you mentioned that you have applied Inertia Relief in previous similar simulations that had nonlinear contacts. Can you try to compare the model setup that was running and the one you are running now and see if something has changed in the model setup? I have attached the Ansys help link for your help.
Thanks,
Akshay Maniyar
