Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unconverged solution due to exceeding limit at uy › Reply To: Unconverged solution due to exceeding limit at uy
Suresh Varma
Hello sir,
I have performed the analysis using a two-step pressure where the initial pressure was 1e-5 Mpa and the second step 0.25 Mpa but the solution only converged till the initial low pressure and unconverged for the second load step.
So I tried a three-step process as well with an increment pressure but still the same problem exists. Can you have a look into this once
https://drive.google.com/file/d/1rm1wFVo9qOdHEMeT2r6alliEcdjnLdZ1/view?usp=drive_link
Thank you for the help
Suresh Varma.
