Ansys Learning Forum Forums Discuss Simulation Fluids 2D supersonic inlet – Meshing Reply To: 2D supersonic inlet – Meshing
SRP
High Y+ values can affect the accuracy of your simulations, especially in cases where you need to capture near-wall flow behavior. To reduce Y+ values to around 1, you should aim for a finer mesh near the wall. Instead of bias, try for manual meshing near the wall.
