Ansys Learning Forum Forums Discuss Simulation Fluids Issue with Void Region in External Flow Simulation Reply To: Issue with Void Region in External Flow Simulation
Paul Stephen
The region called as geom-flow domain is the remaining portion when the blade is subtracted from the enclosure. I kept that as a fluid region and changed the other to dead. During that time I received a new warning message in the console: "Region fluid cannot be deleted as it is completely enclosed by other regions."
