Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys mechanical output only for element set defined › Reply To: Ansys mechanical output only for element set defined
September 11, 2023 at 11:28 am
Ashish Khemka
Hi Ashish,
One approach may be to use submodeling. Perform a global analysis with a coarse mesh and then perform submodeling. With submodeling you will be get a single .rst file.
Ashish Kumar
