Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › User Defined Result (combination load cases) › Reply To: User Defined Result (combination load cases)
erik.kostson
Hi
Check trough the solution combination tool properly and find tutorials as it can do what you need (difference between two different times/steps).
Search the internet for more info on how to use this tool, and the help manual.
Erik
