Ansys Learning Forum Forums Discuss Simulation General Mechanical Instantaneous annealing and creep to represent melting and re-solidifying Reply To: Instantaneous annealing and creep to represent melting and re-solidifying
helen.durand
Thank you for the reply! Could you please clarify what you mean by the following statements?
1). "EKILL will erase the element solution history"
Does this mean that, when an element is set to be alive again, that it will have zero plastic strain?
2). "You should also take care that the elements are sufficiently supported both while killed and after they are reactivated"
Does 'sufficiently supported' mean that each element has enough nearby elements?
