Ansys Learning Forum › Forums › Discuss Simulation › Photonics › No change in phase of optical modulator with change in DC voltage source › Reply To: No change in phase of optical modulator with change in DC voltage source
Guilin Sun
change in phase in a optical modulator using dc voltage should be first simulated in CHARGE, and then import the carrier density as np density attribute. Please refer to this example: https://optics.ansys.com/hc/en-us/articles/360042456054-Electro-absorption-modulator
or
https://optics.ansys.com/hc/en-us/articles/360042328774-Traveling-Wave-Mach-Zehnder-Modulator
https://optics.ansys.com/hc/en-us/articles/360034901753-np-Density-and-Temperature-Index-Perturbation-Simulation-object
The data should be effective index vs voltage for INTERCONNECT use.
