Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Modeling of NFRHT and Photocurrent generation calculation › Reply To: Modeling of NFRHT and Photocurrent generation calculation
Guilin Sun
If the light source is not solar, sure you can use your own source. In addition, you can renormalize the source power from the result. You can also chage the scale in CHARGE to change the actual power used for CHARGE simulation after importing the absorption. If you use solar source, this is easier.
