Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Contact tool error › Reply To: Contact tool error
September 7, 2023 at 6:28 am
Kariuki Karanja
Is it possible to calculate the contact area using the Hertz model. I am not getting the option to calculate the contact area under contact in solution information. Is there a command or code to calculate contact areas you can advise?
