Ansys Learning Forum Forums Discuss Simulation General Mechanical unexpected results when changing the material from structural steel to glass Reply To: unexpected results when changing the material from structural steel to glass
Sampat Kumar
Hi Subhav,
I apologize for the delayed response.
I can see you have attached the result of the contact tool under the solution. Please verify, if you selected the proper contact and target side in the contact tool while evaluating the result. I have created the dummy model and checked with the same version but did not find any differences.
Although your value is also too small,so no issue with it. Is this value-creating any issue in your result? what is the penetration and geometric gap value in the contact tool status under the connection?
Sampat
