Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Question about the definition of rigid part rotating around certain location and › Reply To: Question about the definition of rigid part rotating around certain location and
Reno Genest
Hello Ying,
For a rigid body, the axis of rotation is always through the center of mass. Here is an excerpt from the LS-DYNA User Manual Vol I for *BOUNDARY_PRESCRIBED_MOTION:
So, I guess the center of mass of your rigid body is aligned with the CG point correct? Have  you tried to moved the rigid body so that its center of mass is aligned with point OC for method 2?
Let  me know if this helps or not.
Reno.
