Ansys Learning Forum Forums Discuss Simulation Fluids Free Surface with Wave Boundary Condition Incorrect Initialization Reply To: Free Surface with Wave Boundary Condition Incorrect Initialization
rnegrete
BCs:
inlet: velocity-inlet. Open Channel Wave BC ticked, Al defaults in Momentum tab, in Multiphase tab Free Surface=0, Bottom Level=-5.6, Fifth Order Stokes Waves, Wave Height=1.73, Wave Length=20. I ran command define, then o-c-w-s and check passed.
outlet: pressure-outlet, Momentum: defaults, Multiphase Free Surface=0, Bottom Level=5.6.
top: pressure-outlet, Momentum: defaults, Multiphase Free Surface=0, Bottom Level=5.6.
walls: wall: defaults
bottom: wall: defaults
The bump is in the wave velocity inlet
I did initialize with wave option and the oddity is not visible on the first step but when the wave starts to come in, there's a signifficant change in the slope of the wave giving a similar result during simulation, furthermore, it happens in every wave, not only on the first one.
I tried with and without surface tension.
All the screenshots are from the velocity inlet from where the wave is entering the domain.
Thanks!
