Ansys Learning Forum Forums Installation and Licensing Ansys Products The FLUENT application failed to validate the connection Reply To: The FLUENT application failed to validate the connection
Rajeshwari Jadhav
Hi Allexia,
  1. While installing did the user run setup.exe as admin?
  2. Clear the cache of the Fluent application by renaming the Ansys folder to Ansys.old (type in windows search bar %appdata% or C:\Users\username\AppData\Roaming\Ansys), rename .cfx and fluent.conf folder(C:/Users/username) and relaunch the application.
  3. Can you please check if any antivirus/ security software is blocking the Ansys application?
  4. Can you please ping and telnet the server using the command prompt? Send Snapshot.
