Ansys Learning Forum Forums Discuss Simulation General Mechanical Geometric Gap Inconsistent with Model Reply To: Geometric Gap Inconsistent with Model
Sampat Kumar
Hi Claudine,
Will you please check the offset value that you have provided for the beam or not? You should provide the offset value to the beam as equal to the radius of the beam and select the option "Add offset value and ramped effect". You can find this in the “geometric modification tab” of the contact settings.
Sampat
