Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Door (with door body, rigid body motion, possibility of grounding › Reply To: Door (with door body, rigid body motion, possibility of grounding
tumulpurwar
Hi @mjmiddle
I am unable to get convergence for above model for static stress analysis, So i simplified model, model is below:
The Force applied on top face of Silicone rubber, as can be seen with red color in photo, purple color is Fixed boundary condition.
The rubber is sitting inside grooved cut area of door.Door is Carbon fiber composite material
Frictional contact applied (plaease see 2nd photo in exploded view).
It taking so much time to run, its just ever running, what to do.
Note: For rubber non linear adaptive mesh technique i applied with tetra element
