Ansys Learning Forum Forums Discuss Simulation Electronics Error with NMOS transistor Reply To: Error with NMOS transistor
dedgar
HI Julio, The NMOS device requires a suitable model definition (card) to supply the required parameters etc. Model cards are available in the component libraries for different transistor types. If you have a look at the examples for the DIfferentialAmplfier, you can see the setup (bjt in this case)
Mosfet model cards are found here:
