Ansys Learning Forum Forums Discuss Simulation General Mechanical Stress distribution on hole surface – revolute connector Reply To: Stress distribution on hole surface – revolute connector
eibanez
Thank you Peter, really appreciated. Does the physical pin need to modeled with zero gap in respect to the hole all it will work even with a small play (which will always be there in the real world)?
Regards
Emiliano
