Ansys Learning Forum Forums Discuss Simulation Fluids Need Help: Locating Bad Mesh Elements in Fluent Meshing Based on Quality Reply To: Need Help: Locating Bad Mesh Elements in Fluent Meshing Based on Quality
Federico
You can also check for these cells from the pull down menu Display > Grid > Cells tab, check the Quality box and specify the metric you want to observe.
