Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Issue: Equation gets segmented when defined in a custom structure › Reply To: Issue: Equation gets segmented when defined in a custom structure
August 22, 2023 at 10:12 pm
Hi Mehdi,
I apologize for the late reply. I notice that you are using an extremely large x-span. I was wondering if you had a reason behind that. I believe that this extremely large size is making the structure segmented. If you create something of the size that would be reasonable to simulate in FDTD, you would not see see this issue. For example, the same equation for a x-span of 10 um looks like this:
Amrita
