Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Data table column results change in every simulation(self and mutual inductance) › Reply To: Data table column results change in every simulation(self and mutual inductance)
Fernanda Petite
The results are the same for the 1st and 2nd running. For they change I need to run 5 or more times (that is not working anymore) or, what usually works is to change the scenario, for example: a variable value (length or a coil conductors number), run it, go back for the scenario I want and run it again. But as I am runnig scripts for mutiple simulations I did not try to add this modification in my automation scripts.
As you recommended I tried to create "new data table" more than twice and it did not work.
Also tried to run it again and create new data table. The results are the same.
Fernanda
