Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Porous zone viscous and inertial resistance coefficients › Reply To: Porous zone viscous and inertial resistance coefficients
They are valid for your assumptions: you need to consider whether they're good enough to use as engineering data. We often want to know if condensation will be a problem, we may not care how much there is, merely that it might happen. If you need to know how much condensation there is you need to model it.
