Ansys Learning Forum Forums Discuss Simulation General Mechanical APDL Command to suppress bushing Reply To: APDL Command to suppress bushing
jerome.chassin
I am not really use to APDL Command, and I am kind of lost here. How do you sugere using DLIST? (With the ACT console?)
I marked a remote displacement as “TestBC1” to find it easier in the ds.dat.
Here what I found, in both file ds.dat we have the remote displacement declared. With the APDL script and bushing activated it is also declared, while it is not when we manually suppress the bushings ( everything is normal here). With the script I am suppressing bushing when the APDL Command is called by the solver.
I also checked the "spider" BC should be applied.
