Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › SPH Node To Beam element Contact › Reply To: SPH Node To Beam element Contact
August 18, 2023 at 9:27 am
Loic Ivaldi
You should try the DEM method instead of SPH. With DEM you have a keyword to allow coupling : *DEFINE_DE_TO_BEAM_COUPLING.
As stated by @Andreas I don't think node-to-beam contact is available.
Best,
Loïc
