Ansys Learning Forum Forums Discuss Simulation General Mechanical Unable to get model error message Reply To: Unable to get model error message
Nanda
Hello Amaranth,
I see you doing same setup, but with different loading conditions right? Instead of this, I would suggest you to go for a parametric analysis. You can give the 0.1m/s to 0.6m/s of whatever you're varying in design points. To view the results of certain point, let's say 0.4m/s, make if current and retain those data files.
Here's a introductory video on how to do this:
How to Deal With FEA Singularities in ANSYS Workbench - YouTube
If you want to stick to the same workflow, please see if the below link helps:
Corrupt ANSYS Mechanical Database? You Might Be Able to Recover - PADT (padtinc.com)
Best,
Nanda
