Ansys Learning Forum Forums Discuss Simulation General Mechanical splitBody.Bycutter() Reply To: splitBody.Bycutter()
haibin wu
Of course, I'm very willing to share my method. My method : I will remove the original options along the trajectory to no fusion, and then use the combination of resection of the script code, the outside body as the cutter tool to cutter the outside of the pipe, so that the pipe inside the cylinder, and on the left side of the structure of the tree, cylinder and pipe is divided into two different bodies.
