Ansys Learning Forum › Forums › Discuss Simulation › Photonics › “emepropagate is not a valid function or variable name” in analysis script › Reply To: “emepropagate is not a valid function or variable name” in analysis script
k9johnso
Thanks for the fast response! I tested it, and indeed the EME propagator does run when you perform a sweep, even if you don't put it in the analysis script. I did not expect that behavior, that is a big help! Is there anywhere in the documentation detailing what commands are/aren't design to be used in the 'model' analysis script, and what runs automatically when a sweep is performed?
