Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Parameter Updates Failed for Design Points, Error A2 › Reply To: Parameter Updates Failed for Design Points, Error A2
Sorry, free space in the outlet region, it's 2d so I'd hope the disk is big enough!
That should work. I've never tried a parametric run with a transient flow before as they tend to take ages to run. It's always been easier to build several meshes & run all of the cases at once using a set-up file to speed up the Fluent part.
