Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Parameter Updates Failed for Design Points, Error A2 › Reply To: Parameter Updates Failed for Design Points, Error A2
August 15, 2023 at 2:14 pm
The output parameter is maxVal(Water.Mass.Flow)@inlet . It seems to be working for the DP0 because I can see the value when I write this expression and apply.
In addition, I have 630 gb free space, I don't think this is the issue. Let me know if you need more info.
Thanks again.
