Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Duplicate Nodes › Reply To: Duplicate Nodes
August 14, 2023 at 3:55 pm
Hello Ram,
Thanks ever so much for your help, I really appreciate it.
I assume that the parts are perfectly glued to each other. Therefore, in that case, merging duplicated nodes in their interface can provide a tied contact condition that is good for connection between parts when bonding the interface with glue material perfectly.
I just wonder if I should merge these duplicated nodes with default settings as you can see in the picture,
(✓) Delete Merged Nodes
(✓) Delete Degenerated Elem
(✓) Clean Model
I would appreciate it if you could give me some advice.
Thanks in advance.
Mehdi
