Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Duplicate Nodes › Reply To: Duplicate Nodes
Ram Gopisetti
Hi
Know what does this " Dulicate node merging" is al about, its is the shared topology option and usually used to remove an contact and enforce bonded ( tied constrained )  between the parts.
so its now upto you to see ,  if you need those constraints or not.
cheers, ram
