Ansys Learning Forum Forums Discuss Simulation General Mechanical How to set the maximum displacement Reply To: How to set the maximum displacement
peteroznewman
Frictional contact is used to prevent two surfaces from penetrating each other. If you have that and the inner edges of the two disc springs are initially touching, forces or displacements can squeeze the two discs together and the contact will develop out to a larger radius until the outside edge of the two disc springs are touching.
