Ansys Learning Forum Forums Discuss Simulation General Mechanical Solution not forming as saying internal solution magnitude was reached Reply To: Solution not forming as saying internal solution magnitude was reached
peteroznewman
The beams are not connected. Insert a Mesh Edit and perform a Node Merge to connect the beam elements.
