Ansys Learning Forum Forums Discuss Simulation Photonics non uniform electric field in FDTD simulation Reply To: non uniform electric field in FDTD simulation
Guilin Sun
For non-periodic with PML, you cannot directly use plane wave. Instead, you can use TFSF source. and the intensity will not be uniform when the hole is there. This is the physics for nanophotonics.
