Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ANSYS FLUENT ENTHALPY CALCULATION › Reply To: ANSYS FLUENT ENTHALPY CALCULATION
The value you're getting is probably correct (assuming you have a well set up & converged solution), but you may be misreading the value. The solid has an enthalpy of formation value, and the melting heat is in addition to that. Assuming there is no chemistry the value of the formation enthalpy doesn't really matter.
