Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › damping and hourglass coefficient in SSI example › Reply To: damping and hourglass coefficient in SSI example
Ushnish Basu
In general, an entry of zero sets the default value as listed in the manual.
DAMPING_FREQUENCY_RANGE applies to all parts for PSID=0, except for those specified in other DAMPING_FREQUENCY_RANGE cards. This is mentioned in the description in the manual.
Note that these examples are illustrative only, and you should set parameters as appropriate for your model
