Ansys Learning Forum Forums Discuss Simulation Photonics Running Lumerical Using Xvfb – Error Reply To: Running Lumerical Using Xvfb – Error
Amirali Atrli
@Lito Yap,
I have successfully initiated and run the tmux session. I have confirmed this by detaching from the session, exiting the SSH connection, reconnecting, and reattaching to it. Also, I have checked the Xvfb displays after detaching from tmux, disconnecting from the SSH server, and reconnecting to it, using the same procedure as mentioned in the document Running CAD jobs on headless Linux systems (without GUI) (“ps -ef |grep Xvfb”).
Is there any other possible issue at hand? Also, is there a reason as to why the procedure that used to work fine (e.g. "xvfb-run ... mode-solutions -run " in the tmux session, without detaching) does not work anymore?
