Ansys Learning Forum Forums Discuss Simulation Electronics Issues when running SIwizard for differential high-speed links Reply To: Issues when running SIwizard for differential high-speed links
alexandre.lecomte
@Nathan Thank you for your answer, it worked for me.
@Dan So I have tried some stuff to attempt correcting the errors, but did not succeed so far. This is the logs on aedt:
I tried modifying my source to PRBS, but still get the "no valid bit sequence" error.
