Ansys Learning Forum Forums Discuss Simulation Fluids Bad termination of fluent simulation Reply To: Bad termination of fluent simulation
Federico Alzamora Previtali
Your UDF is likely the culprit if it runs fine without it, not in the syntax of the code since it compiles without errors but in how it is set up or what it is doing.
Can you show us what your UDF looks like?
