Ansys Learning Forum Forums Discuss Simulation General Mechanical Modelling laminate defects (delaminations) with Shell elements + layer offset Reply To: Modelling laminate defects (delaminations) with Shell elements + layer offset
Robert Mehlig
Additionally: since I am defining the defect area twice, once in the LS for the whole plate and the second in the LS for the defect area, does this cause a problem? If I define the defect area to include only the aluminum, not the original plate layers, does this cause an contact issue between the CFRP plate and the aluminum disc?
