Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Modal analysis of simply supported beam with circular cross section › Reply To: Modal analysis of simply supported beam with circular cross section
August 3, 2023 at 1:57 pm
Abhishek Chauhan
As i tried half cross-sections by using the named selection mesh node but it is also not working.
As I used avoid rotation x also it is not working.
can you tell me the other method or give any reference?
