Ansys Learning Forum Forums Discuss Simulation Photonics Monitoring frequency outside source limit – trusting results Reply To: Monitoring frequency outside source limit – trusting results
Guilin Sun
You are right, frequency points inside the source limit can guarantee that the source spectrum has sufficient amplitude and thus accurate Fourier transformation in the frequency domain. For nonlinear simulation, when new wavelength is created, you can set this:
o
