Ansys Learning Forum Forums Discuss Simulation Fluids Turbulence Modulation Reply To: Turbulence Modulation
Vicky
Hello Rob,
Thank you for your answer. Yes, I reviewed Rocky's manual but he only described the three options that Fluent proposes, that is to say (per-phase, dispersed and mixture, but they do not add more information about the equations that Fluent is using to calculate the 2 source terms.
Thank you for leaving a message for Rocky's team. I will be attentive to any answer they can provide.
