Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Replicating a section of cylinder with elements into full cylinder › Reply To: Replicating a section of cylinder with elements into full cylinder
Praneeth
Since you are forming an array or patch elements, the separation between the end elements of the two consecutive arcs should be equal to that of the consecutive elements in a single arc (unless your design specifications differ). So, the extra blank spaces at the ends of an arc should be trimmed.
