Ansys Learning Forum Forums Discuss Simulation Electronics Replicating a section of cylinder with elements into full cylinder Reply To: Replicating a section of cylinder with elements into full cylinder
Praneeth
In that case, it may be required to connect (unite) these arc elements. Or, you delete the intersecting portions. Please use which ever option helps you.
