Ansys Learning Forum › Forums › Discuss Simulation › Fluids › LRN SST K-omega and Transition › Reply To: LRN SST K-omega and Transition
July 28, 2023 at 3:55 pm
Hello,Â
If using the K-Omega Viscous Model with Low-Re Corrections turned on, that does not automatically turn on transition modeling. You need to manually select either one of the transition models from the Transition options.
Thanks,
Kalyan
