Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Biegen eines Halbrohres › Reply To: Biegen eines Halbrohres
Sampat Kumar
Hi Andreas,
The length of the pipe will increase if you attempt to pull it while both ends are fixed. So, if the pipe’s length increases while maintaining the 16mm circular arc radius, are you okay?
Sampat
