Ansys Learning Forum Forums Installation and Licensing Ansys Products Changing Steel Material from A36 to A992 Reply To: Changing Steel Material from A36 to A992
Sahil Sura
Hello Naresh Jogi,
The material properties mainly affecting the results of the linear elastic static structural analyses can be the Modulus of Elasticity (which plays a key role in assessing the stiffness) and Poisson’s Ratio. The Tensile Yield Strength also plays a key role when determining the safety factor, but this does not affect the calculation of stress and deformation.
So if checked via Ansys Material Library, Structural Steel ASTM A992 has a Young’s Modulus of 2.1239e+05 MPa at 23 Degrees Celcius, while from the other sources for the same conditions, Structural Steel ASTM A 36 has a Young’s Modulus of 1.9994e+05 MPa. So if noticed the difference in Young’s Modulus, there must be a very minor deviation observed in the results.
Thus considering this the results should vary to a certain extent. These FEA algorithms are based on numerical methods and thus have limitations; accuracy can be compromised as per the application to a certain extent and thus is up to the user.
A simple hand calculation would also help in addressing the difference observed in the results, which can be a great baseline for comparison.
The solution to the problem can be -
Re-verifying the material properties from physical testing
Turning on Large Deflection to capture better plasticity effects
Refining the mesh and checking the boundary conditions
Hope this helps!
Thanks,
Sahil
/forum/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
