Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modeling internal using porous media model – fluid get stuck under the internal › Reply To: Modeling internal using porous media model – fluid get stuck under the internal
July 27, 2023 at 12:45 pm
If you set phase specific resistance coefficients and the gas has somewhere to go along/away from the porous media then, yes it will. Otherwise the gas has to go somewhere!Â
